Old 14-11-2006, 08:55 PM   #1
richo77
richo77's Avatar
Default Problems after reset
Hey guys,
Need some qualified advice please -
AU XR8 III Auto
CD Stacker jammed so I disconnected the battery and reconnected it, result unjammed CD stacker.
Car ran rough on reconnection so i did the reset procedure as described here.
Problem is the car is not running as well as it used to. The car starts well but when I move the selector to put it into reverse the revs drop to about 500 and then quickly rise up again when when it is locked into reverse.
Also after the car has been in Drive and then put into neutral it stalls most of the time. Any ideas what the problem is here and how to rectify without visiting Ford?
Nathan
Also lately its becoming very difficult to hot start after being off for a short period of time. I'm not sure that this is related to the battery being disconnected.
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 09:02 PM   #2
Stav
Smile
Stav's Avatar
My car did the same thing with stock ecu settings and cam.The idle went to buggery. The computer has to relearn all of the wear and tear of the car to run properly again.Give it a week to hopefully get back to normal.
Old 14-11-2006, 09:02 PM   #3
MRJUCY
Fordless
MRJUCY's Avatar
They take awhile after being disconnected to come good again they can sometimes need a fair few kays to relearn before they idle etc well, I dunno about the hot start issue but they can be a bit grumpy about starting without a bit of throttle sometimes.
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 10:25 PM   #4
bigjim
I've also found that mine does exactly the same sort of things when i disconnect the battery, and it can also be a bit of a pain when hot starting.
bigjim is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 11:36 AM   #5
richo77
richo77's Avatar
Thanks guys, its been nearly a week since i've reset it and its still not right, will give it another week to settle and see what happens.
Old 15-11-2006, 01:42 PM   #6
HLC
Audi S3
be thankful it isnt stalling haha
when i got a new battery in my old ED. it use to just stall. so embarrassing stalling an Auto :
Old 03-01-2007, 02:38 PM   #7
richo77
richo77's Avatar
Hey guys,
Well its been a month or so and my XR still has issues with stalling out 4/5 times when put into neutral and occasional misfiring at a steady 2000rpms.. its not using excessive fuel (I got 700kms from the tank from a spirited drive into Kalgoorlie yesterday) and doesnt feel like its lost any power so i'm stuck as to what to check next..
Any ideas what i should be looking for? It still has the original leads on it, could this be an issue?
Old 03-01-2007, 02:50 PM   #8
StealthAu
and all you did prior to this issue was disconnect the battery?
Old 03-01-2007, 02:52 PM   #9
JC
JC's Avatar
The usual suspects:
dirty MAF
dirty ISC valve
blocked fuel filter
leads
plugs
etc etc
Clean/replace as necessary. I'd start at the top of the list and work down. I have a cheap brand new set of leads I could send you. $100 and they're all yours - they work fine for petrol, but no good for gas.
Ford Performance Club ACT
Old 03-01-2007, 05:07 PM   #10
angryboy
Hey man just reset the computer again by disconnecting the battery negative terminal, turn key on and hold the brake for ten seconds,hook up the battery and start it and do the relearn.If that doesnt sort it there could be another problem?
:sm_headba
angryboy is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 05:37 PM   #11
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
mine has these systems on and off. will do it for a month or two then be fin for a while then sick again... all the same symptoms described, and mines an auto forte.
i did all of JC's checklist and it really hasen't fixed buggery, except the fact that most these parts needed the clean and replacements anyways.
next step, a 1/4 million $ visit to ford to have the forte plugged into the matrix...
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 05:38 PM   #12
richo77
richo77's Avatar
Yes was running great before battery disconnect, ever since then having the problems.
Old 03-01-2007, 05:46 PM   #13
richo77
richo77's Avatar
I havent heard of turning the key and holding the brakes before.. where do you know this from angryboy??
Old 03-01-2007, 05:49 PM   #14
richo77
richo77's Avatar
Originally Posted by JC
The usual suspects:
dirty MAF
dirty ISC valve
blocked fuel filter
leads
plugs
etc etc
Hi JC, had a quick search on cleaning MAF and couldnt find anything, is there a tutorial on how to do this??
Old 03-01-2007, 06:37 PM   #15
JC
JC's Avatar
It's pretty easy. Just a thought - did you do a reset because you installed a K&N or other simlar "oiled" filter? If so, then I'm strongly betting on the MAF wires being covered in oil.
Easiest way to clean the wires is to carefully wipe them with a cotton bud covered in carby clean. Do NOT break the wires though. Maybe just spray the wires with Carby clean and then lightly go over them with a cotton bud, then put the MAF back into the intake and start her up.
Old 03-01-2007, 08:19 PM   #16
richo77
richo77's Avatar
It does have a K&N panel filter so i'll try cleaning the MAF. Reason I had to disconnect was because of a jammed CD stacker. Dont you love cars, fix one problem, create another!!
Old 03-01-2007, 08:30 PM   #17
angryboy
Battens performance gave me the reset procedure so thats how you do it. step 1 remove negative battery lead.
step2 turn key to on position
step3 hold brake for ten seconds
step4 reconnect negative battery terminal
Start car and commence relearn, i didnt ask them about the relearn but i just use 1 that ive seen on here before, 1minute running in park, 1 minute running in park with air con on,1 minute in drive running, 1 minute in drive running with air con on and i have never had a problem with my eb or au. Im not 100% sure but i think if the ecu is reset properly the car relearns when u drive it
:sm_headba
Old 25-01-2007, 01:30 AM   #18
Bung
Bung
Richo
My AU3 did the same thing after resetting ECU. Come up to a stop at roundabouts and idle would drop and stall 20% of the time. Followed the reset on this site (Disconnect, 2 minutes, 2 minutes, etc) and it didn't improve. Reset it again being exact on the times recommended by a member of this site and drove it for 10 minutes changing the throttle position constantly and then did a quick run to Denmark from Albany (50km). Better economy, less trans kickdwn on hills and problem solved.
Bung is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 01:03 PM   #19
richo77
richo77's Avatar
Problem solved by disconnecting it again and ignoring restart procedure, just reconnecting and taking it for a drive, car has never run better
Old 25-01-2007, 02:22 PM   #20
b2tf
not here much anymore
b2tf's Avatar
Yep I agree with this, I never use any relearn procedure or junk like that, just drive the car and it will soon work it all out again.
2024 F150 XLT
