Old 16-11-2006, 06:23 PM   #1
mk1gt500
Default xr8 camshaft
Just asking will the au series 1 xr8 computer cope if I the change the camshaft to something that is a different in profile as it sounds like I have some lifter noise and if I change the lifters I would to change cam as well.
mk1gt500 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 08:54 PM   #2
EvilChief
Boost Addict
mild cams can be handled by the standard ecu, but dont go overboard
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 16-11-2006, 09:10 PM   #3
philstoj
philstoj's Avatar
Dont risk it, a mild cam could be much bigger than the stock one and create problems.
Do a cam and edit, no problems, and no extra stuff ups.
Im speaking from experience, as this has happened to the missus' ute.
Old 16-11-2006, 09:31 PM   #4
nitroman
nitroman
nitroman's Avatar
Been there done that... Get a mild cam off crow and a capa flash tuner and edit and you'll be rockin'. I went too hot with my cam which kills the bottom end, but I can go 250...
AU1 XR8
E303 cam,Crane Rockers,Crane double valve springs,Rollmaster roller timing gears,Crow +80" pushrods,SS cold air induction, 2 1/2 inch custom exhaust,Capa flash tuner.KONI shocks.
EF fairmont wagon.
GASGAS 400 enduro.
Honda hr192 mower
nitroman is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 09:46 PM   #5
b2tf
not here much anymore
b2tf's Avatar
Phil do you have any info on what cam is in yer mrs' ute? Im guessing it was part of the Herrod pack added to it (I remember reading about it when she got it).
2024 F150 XLT
Old 16-11-2006, 10:01 PM   #6
philstoj
philstoj's Avatar
I had another cam, which was supposed to be the same, and it was called an SVO 210, though i cant remember the specs.
It was bought from a so called expert, and i heard that herrod used the same cams for the package, later he used a trick flow st1, so i reckon they could be similar to that cam.
Ill have to ask rob when i get the chance.
Old 16-11-2006, 10:17 PM   #7
b2tf
b2tf's Avatar
be interested to see what you find, its an auto right? im after an idea of what to get in an auto as a good street performer, but not too crazy.
2024 F150 XLT
Old 16-11-2006, 10:24 PM   #8
philstoj
philstoj's Avatar
Yeah its an auto, very torquey, though it needs an edit, as the chip just doesnt do a good enough job.
My plans for it are an edit, stall, and some diff gears and it should easily see 13's everyday.
Old 17-11-2006, 12:56 PM   #9
xr8ute
Back on the road
xr8ute's Avatar
Being MAF based, the V8 computers can handle changes in airflow with the stock tune soooo much better the the MAP based I6 computers.
Ive got a Crane 2030 (216/220 @ .050") with stock computer. Idle is lumpy-ish and it can stall after emergency braking (very rarely), but everywhere else it is magic. I would imagine even better with a custom tune as the AFR's are still less than 11.0:1 at WOT.
So far its run a 14.15 @ 98mph in an auto XR8 ute with exhaust, std converter, and 3.9:1 gears.
Old 17-11-2006, 08:06 PM   #10
XR8-260
Just wondering if mild cams + edit are a safe mod to do i.e. no long term mechanical problems?
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2006, 08:20 PM   #11
philstoj
philstoj's Avatar
The cam in the missus' ute would be as big as a 2030, with the 1.7 2 rollers, but it barely went when the chip shit it self.
The stock ECU wouldnt run it, even after a few klms, and ended up destroying the cats and fouling the plugs, maybe its more of a cam than i thought.
