www.TUFFCARPARTS.com
Hi All,
I'm a bit fresh when it comes to towing, so just wondering if my AU wagon will be capable of towing another falcon on a car trailer? It has a trans cooler fitted so that part of it is ok, but I'm more worried that the load will be too heavy for the AU. Any thoughts? Thanks, Justin. |
![]() Join Date: Dec 2004
It will tow it easily so long as the trailer has brakes. Falcons were designed to tow, think of all the people cruising around with 2 tonne caravans on their annual Xmas road trips.
windsor user
the load shouldnt be too heavy, but please get a bit of experience towing before you slap a car trailer on and tow another car.......
it can be quite dangerous.. |
just take it easy and make sure the car is attatched to the trailer VERY securely.
#5 | |||
I love AU XR8s
Should be fine, just watch your suspension. If you feel you are sitting low on the rears when you are towing, seriously think about getting a different suspension setup. Also, dont skimp on safety, get the best brake pack on the trailer that you can afford. A good quality towpack rated for 2300kg is needed.
However, remember to check with your state roads authority as to the legality of the load you will be towing.
FPV & XR Owners Club of Qld
Want more info on our club? fpvxrqldinfo@gmail.com or see our Club Section My Garage: AU II XR8 Sedan "Lil T" Hyundai i30 SR yeah baby! |
growing up is optional
Yes, make sure you are not exceeding the towing capacity of your set up.
If its an auto, manually select 1st gear when taking off, this applies the rear band and is kinder to the trans. Do not use over drive either! |
#7 | |||
I tried to hire a trailer to tow a falcon once and the hire place refused to lend it to me, said I needed to come back with a 4WD
#9 | |||
windsor user
Hmmm, I'm not quite sure about the towing capacity of the setup I've got, hadn't even thought about that. As for the trailer, I was just going to hire one from a servo, but not sure whether they'd have brakes or not.
It sounds like it might be safer for me to just drive the other car back, was just reluctant to do so as it's fitted with a mini-spool! |
I've got a 1600kg tow pack. Add the weight of the car trailer (600kg or more) and the weight of the car being towed (around 1200-1300kg?) and you easily are towing more than you should
#12 | ||
Spin 'em Habib !
No Drifting wiht the Trailer in Abandoned Industrail Estates with Wrecked cars Either ,
AU2PWR |
#13 | |||
#14 | |||
Back on the road
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#15 | ||
If you have the heavy tow pack you wil be fine ,most places that hire car trailers should know what you can and can't do plus most of their trailers are fitted with trailer breaks if that the trailer is able to fit a falcon on .
But if you feel you have to ask ,yer maybe you should try driveing it home and have ago at towing when you have time to learn rather when you have to |
#16 | |||
Walking with God
![]() GK
#17 | ||
all servo car trailers should have a slip joint in the hitch thingy..
it will push back as you brake and applies the trailers brakes.. just remmeber to flick the spacer over when reverseing otherwise it applies the brakes while you reverse LOL we have towed a few cars from sydney to brisbane on hired cartrailers.. an R31 shape pintara wagon an XF falcon 4 speed manual my uncles NL fairlane V8 NA fairlane I6 all managed fine the pintara was the worst trip as the engine was blowing/blew the head gasket or somthing due to the owner driving it like a bat outta hell.. just take it easy and remember a car trailer is like 8 feet wide.. so dont cut corners!!
#18 | ||
WRX terrorist
Whatever you do please place the car on the trailor properly, the amount of cars I see towing other cars where the car on the trailor is too far forward. The car towing has it's ar$e on the ground with the nose 3 feet in the air whilst they struggle to turn the nose of the car around a round about........
#19 | |||
#20 | ||
windsor user
as kooky said, but i'll add.....if your car is sitting like that, your steering and braking is drastically reduced, and the whole rig will sway like mad at speed
#21 | ||
yep .mine is my tow car bought for towing cars (mainly anyway),have towed gtrs,commodores, utes and heaps of escorts BTW,I only have a 1600kg bar and no cooler although ,I going for a 2300kg bar and cooler when one comes up.
Manuals get hot and destroy 5th gear if worked too hard from towing, hence the 1200kg tow limit.and why I sold my xr6 manual ute. |
#22 | |||
Ha ha, I had an XF a few years back that had that exact look! Sexy!! |
#23 | ||
After everyone's replies, I decided to drive the car home rather than tow it - seemed like the safer bet given my limited towing experience.
As a side note, the car I bought has a mini spool fitted, and I must say I am a confident driver, but a mini spool is without a doubt the stupidest, most dangerous tight wad modification I have ever come across! Yeah it would be awesome for burnouts and circle work, but driving around on the streets it is downright dangerous. |
#24 | ||
Formally Kia Chaser
Good to hear that you made a sensible desicion... I twoed back my old HZ on a car trailer in the AU with a 1600kg towpack, and lowered rear... end result:
EDIT: Note the giant concrete scrap marks near the front wheel from backing the trailer up over the kerb... lol... ![]()
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#25 | |||
BTW: I towed this about 100km with my ute .. thru the Macedon ranges and along the Calder ![]() .. no worries |
#26 | ||
windsor user
i was actually trying to find this thread when you asked the question, but couldnt find it
http://www.fordforums.com.au/showthread.php?t=36068 please have a read of that....theres good info in there on towing.. |
