Hi guys, just a question. Lately I have noticed a squeaking sound as I go over bumps etc comming from under the car around the front wheels, When i got my car serviced and a wheel alignment they made me aware of a problem that can eventuate into a more serious problem if not taking care of soon, they said that the bareings on the two front wheels or something like that are old and need replacement because the wheels are able to move from side to side about 5cm when hoested up, when the two back wheels dont move at all.
So what else could it possibly be ? I am due to get the car lowered getting a new cam kit, springs and shocks but it might be worth getting whatever the problem is out of the way ??? any suggestions. cheers |
Aspiring mr efxr
i have this. was in the front wheels. pull the hub apart and repack with grease.
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
Ex EL Falcon
I've got squeaky noises in my EL as well... I don't know if its wheel bearings or not but I do know my tie-rod ends are rooted, as are my rear swaybar bushes.
Our Lady of Blessed Acceleration, don't fail us now! |
Ok seeing i am still learning heaps about cars what is a tie-rob end ?? and what is a swaybar bush?? what do they do and is it a big problem if these things are F%&ED!!
yes it is a problem if they are stuffed the tie rods are what connect your stering rack to ur hub assembly your swaybar bushes are what connect your sway bar to your car and your weel bearings are what your weels spin on all are farily inexpensive to fix and are worth doing as you will notice an improvement in handaling.
inexpensive aye ?? i like the sounds of that thought it would be a fair expense thought it was a major machanical problem but hearing that lets me breathe a little easier thanks for your help guys due to get it checked out so i will post when i find out what the problem is
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
I have a squeaking noise as well but don't believe everything you hear from a mechanic - get a second opinion as they may just be guessing whats wrong.
My squeaking noise is coming from my camber kit as the bush's are stuffed.............. As you can see t from all the answers on this here are many squeaking noises that can come from the front of a Ford, if you don't know anything about cars and are just learning either get another member to have a look or get a second opinion from another mechanic BUT just tell the second mechanic you have squeaking noises and don't tell him what the other mechanic thinks..........
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
yeh definatly a good idea to get a second opinion and if ya can take a mate who knows a bit about cars in with you, or get a member to have a look at it for ya
ED4LYFE
I've got the same problem with my ED, shits me to tears.
Although I need to get my guards fixed first, keeps scrubbing.
giggity |
HANK
i have this in my EB. i think it is just the shocks are *****. the mechanic when i got it serviced said the shocks were soft and leaking? hopefully its an excuse to get lowered shocks n springs!
1992 EBII Fairmont Lowered 30mm on kings springs and monroe struts/shocks Performance catback exhaust with stainless 3 in tip! Shift kit! Tinted windows n tail lights. Pioneer 200w flip face head unit 600w pioneer sub backed by my nu 640W kenwood 4 way amp Eclipse 6x9s and 6's Clear front and side indicators 115 rwkw on regular, not bad for pod, catbak! Back on the rd! nothing can stop us, not a defect or even a stoby pole!! BAHAHA ![]() |
|AFordEd|
yep so does my ED Classic, especially on hot days, every bum or speed hump u get the squeeeeks, i always thought it was somthign to do with the shocks wearing out? oh well im getting new shocks n springs n cambre kit on thursday so i'll soon find out
#12 | ||
phew, i thought i was the only one who had this problem. my el sounds like i am squashing a bird everytime i hit a bump lol. mines from the rear, might be from my accident, i changed every bush except the swaybar bushes.
#13 | |||
I'm back. Same car.
#14 | ||
xc - my other love
i would still suggest changing your wheel bearings... it's pretty simple, inexpensive and will take about half hour each side...
Power = Money
How fa$t you wanna go?? apparently pretty fast - 400rwkw BF xr6t! FG F6 bottom end - GTX3582 - Nizpro 4" exhaust - Nizpro cooler - plazmaman intake - piping - plenum - batt relocation - injectors - surge &044 pump - valve work & valve springs - XCAL |
#15 | |||
Oops, I slipped....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#16 | ||
Ok well if i was to get new bush or clean them whatever it is you do what prices are i looking at to get bearings, bushes, swaybar. anything else worthdoin ?? prices thanks
