www.TUFFCARPARTS.com
Hi All,
I'm currently removing a Redback exhaust from an EL sedan that I'm wrecking. I know how to remove it, but the whole exhaust is 1 piece from the cat to the tail pipe, so just wondering where I am best to cut it, so I can get it out? I only ask, as I want to cut it in the best place for it to be welded again once it's fitted to my EF. Thanks, Justin. |
if there is a resonator cut it where that joins into the pipe, try and find some 1mm grinder discs they work a treat and come in handy in many situations.
Interceptin'
Why do you need to cut it? I'd leave it in one piece and unbolt it.
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' |
#4 | |||
#5 | |||
#6 | |||
When you say that, are you saying jack up the body, not the diff? Have you managed to get an exhaust out this way? |
does it have any mufflers or resinator
best place to cut it would be before the diff. Unless you can get it on a hoist or feel like dropping the diff then you will have to cut it.
LOW AND SLOW
Undo drivers side rear shocker jack body right up and you will be able to manouvere the complete system out.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping". |
![]() Join Date: Jan 2005
Your wrecking it right? Tip the thing on it's side and it'll be easy
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
if u gotta cut it make it on one of the least supportive sections
#12 | |||
I think I'll at least try removing it in one piece, but my gut feeling is that I'll be attacking it with the angle grinder! |
#13 | |||
likes falcon's
www.carhubsales.com.au |
#14 | |||
I don't think I'll be tipping it on it's side.... would make things easier though! |
#15 | ||
at the middle muffler it sleeves into it should be able to undo clamp there and seperate may take some work but yeh wont be that hard thats way i done in previous
#16 | |||
