Old 12-03-2007, 02:31 PM   #1
tolly
XLSMARLIN
Default Au gauge face install
hi guys im new to the aufalcon forum just bought my 2001 XLS Marlin 2 weeks ago and i'm keen to start doing some mods...sooo many options!!! . i noticed on ebay last week that some guy is selling white face gauges for the au on ebay for about 80 bucks. Just wondering if this is easy enough to do yourself or whether you can run into probs when you start pulling the gauge pins out. I've heard of people mucking around with this and that they get problems where one of the gauges might stick/not respond. Anyway guys if anyway has had any luck installing one let me know how it went.
Tolly
tolly is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 02:42 PM   #2
superroo
You can't stop the signal
superroo's Avatar
Well i've pulled my cluster out, face off, needles off a couple of time and have had no problems. The way i recalibarate it all is to put it all back together with the lens off, turn the ignition on, then adjust the needles to original values.
I've only had one needle be half funny, and that was the petrol guage. Just had to pull the needle back away from the face.
However, personally i wouldn't get one of those faces. Paint the surrond and then do led lights. That together looks great.(see below)
However, now my needles are white (red has been sanded off with 2000 grit) so they show up with the blue led's
PS. Welcome to the forums. Sounds like you've got a nice car.
Old 12-03-2007, 02:52 PM   #3
tolly
XLSMARLIN
nice work... is the cluster difficult to take out? im guessing once it is out it's relatively easy to change over the leds?
i have an auto and i was also thinking of changing the leds beneath too...i've seen some photos of people putting them under the shifter. it looks pretty easy...6 screws i think... also anyone else who changed the face or modified their cluster post them so i can check em out for ideas...
Old 12-03-2007, 02:59 PM   #4
superroo
superroo's Avatar
Cluster is so so to get out, can be a pain, can be easy.
As for LED's, you've got to solder resistors to the led's. then modify bulb holders, then re-install. Casper has the Tutorial/how to for it, and it should re appear on aufalcon.com soon
Old 12-03-2007, 06:15 PM   #5
tolly
XLSMARLIN
oh damn i thought it would be a lot easier than that for the shifter lights. Now with the cluster when you said that you put the needles back on you turned the ignition. wouldn't it be easier to do replace the needles with ignition off so everything is reset to zero? how do they come off do you just pull them off?
Has anyone got any unique mods that they've done to their interior?
Old 12-03-2007, 09:25 PM   #6
Mark351
Built Ford Tough
Mark351's Avatar
Instead of painting my instrument mask, I had it modicoated in a snakeskin pattern, along with my door handles and the trim piece above the passenger airbag. Very unique as far as I know because the pattern had to be imported for the job (luckily someone was getting a table coated in the same pattern?!?!) and unless someone has had it done since I'm it! The pieces can be seen in pics on modicoat's website, and pics of them installed via the link in my sig. Done a few other things. My manual gear shift got a new shifter, shift level, gear boot and I added the chrome ring from a tseries. Have a project underway that should spruce up the interior a bit more.
Good luck with your mods, going unique is a good thing so let your imagination go nuts!
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 09:38 PM   #7
AUXRVIII
Narva have LED's availiable for instrument clusters which are 12volt & no mods are needed to fit them.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 09:35 AM   #8
tolly
XLSMARLIN
that sounds great, new lights with no hass. are the leds in the cluster the same as the shifter?
DeathXR - saw your snake skin interior...looks sweet man. do they use like a film for modicoat or what?
Old 13-03-2007, 10:27 AM   #9
HLC
Audi S3
so does Parklea markets here :P and i know which is certainly cheaper :P
Old 13-03-2007, 11:59 AM   #10
Mark351
Built Ford Tough
Mark351's Avatar
I believe so, I think you can see the proces on their wesite. The end result is really excellent too. Not a cheap process, but I'd certainly do it again over painting it.
Old 13-03-2007, 02:17 PM   #11
tolly
XLSMARLIN
the modicoat stuff looks great i just checked out their site. I think i might get that done once i get the cash, it's just a matter of taking out the console or dash yourself or whatever you want for them to coat. i checked out the process and it's actually dipped so it's not like cheap laminate **** or anything like that. It's about $350 for the dash, $200 for the console. I They're in Bris too!
I just went to supercheap as well and got an Ellery's manual for Ford falcons. it's great there's so many answers to questions ive had in there. It has diagrams and instructions to remove/install interior so it's great for DIY stuff. Best $40 i ever spent!
Old 14-03-2007, 01:16 PM   #12
AU dude
Flying high...
AU dude's Avatar
i was looking at changing my cluster to a white faced one from ebay, but then i found out that some of them are cheap printed overlays.
this one i found is a professional one on ebay...
Ford Falcon AU FORTE Cluster WHITE FACE GAUGES
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 02:17 PM   #13
tolly
XLSMARLIN
yeah they were the ones i saw on Ebay i thought 80 bucks is pretty good value. i reckon a white one with blue lights would look sick
Old 14-03-2007, 10:34 PM   #14
tolly
XLSMARLIN
i've found the site, do you know what globe type i need?
Old 15-03-2007, 08:20 AM   #15
toolchick01
Now with an AU XR6
toolchick01's Avatar
I've seen that guy on ebay, but I'm after the XR cluster. Only problem with them is that from the photos, they dont have the tickford logo on them. I suppose I could ask if he could do it. If I get one I will let you know how it goes.
Stop chasing me! I don't have any donuts!
1999 AU1 XR6 VCT - Now with a momo steering wheel!
Manual - 18" Koya Race Tek's Black with polished lip - Lowered - Series 2 tail lights - Pioneer P80 Head Unit - Clarion Front 6" Splits - JL 5x7's Rear Coaxials - Clarion 4x90w RMS amp - Clarion DPX1800 800w RMS mono - 2 Clarion PXW1251 400w RMS 12" subs
Team Deck Chair Member ............ Once you sit down, you'll never stand up.
toolchick01 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 11:57 AM   #16
AU dude
Flying high...
AU dude's Avatar
Do you mean like this one?
ford falcon au S2,3 XR6 tickford cluster
