Old 09-04-2007, 05:08 PM   #1
ED_Boy
EL Futura T5
Default EL Engine Enquiry
Hello everybody, i recently bought a 97' EL Falcon Futura 5spd nd i heard that the last of the EL's got the AU motor in them, or a hybrid between the two, is this correct? and also what are the advantages of putting an XR6 head on the 4.0L thats in it?
any help would be helpful
ED_Boy is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 05:18 PM   #2
Jason[98.EL]
Jason[98.EL]'s Avatar
being a 97 you would not have the hybrid
i have a 98 and it is a hybrid and it a **** of a thing i cant get a normal wade or anyother grind for it 400plus for a cam
jason
[SIGPIC][/SIGPIC]
Old 09-04-2007, 05:40 PM   #3
ED_Boy
EL Futura T5
cheers man thanks for the help, so do ya know much about the XR6 head conversion?
Old 09-04-2007, 05:42 PM   #4
ED_Boy
EL Futura T5
Hello everybody, i recently bought a 97' EL Falcon Futura 5spd and i heard that the last of the EL's got the AU motor in them, or a hybrid between the two, is this correct? and also what are the advantages of putting an XR6 head on the 4.0L?
cheers Daniel
Old 09-04-2007, 05:51 PM   #5
XR6_661
Cane Farmer
XR6_661's Avatar
I wouldn't mind knowing if it's true that the last of the ELs had AU motors.
I have a 98 model EL...I'm dead sure that's the last cos AUs came out in 98
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 05:52 PM   #6
335JET
@jas_23_
335JET's Avatar
hey, what colour is it, sounds like mine 97 EL Futura 5 speed, ive still got the standard head but i did put an xr6 cam in.
seems to go ok.
335JET is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 05:55 PM   #7
335JET
@jas_23_
335JET's Avatar
the motor is a mix between EL and AU, hence there known as hybrids.
they have an EL bottom end and AU head.
Old 09-04-2007, 06:01 PM   #8
rmack
rmack's Avatar
History 101
In January 1998, the 'hybrid' six was introduced to allow the early conversion of many of the Geelong machine lines to AU specifications. Externally the engines were identical to the earlier EL Falcon engine however featured full AU specification blocks as well as the AU's low inertia valve train.
Unfortunately this did not extend to the AU's head, head studs or head gasket so these engines are still subject to head gasket failure.
This change did however involve changing the normally parallel valve springs to the newer conical AU items requiring new tools when servicing.
The valve stem seal was also redesigned in these engines to accommodate the thinner stem of the inlet and exhaust valves. Included in the redesign was a new installation specification for the valve stem seal.
The block change necessitated a special crankshaft to be made, with large main bearings to suite the AU block and EL size big ends to allow the EL spec conrods still to be used.
The crankshaft can be identified by the letters 'VR' cast into it verses 'WR' which signifies a full AU spec crankshaft.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 06:05 PM   #9
ilsautomotive
Former E-Series Member
Great info Rmack!
I believe one must be very careful when installing an aftermarket cam in the '98 EL sixes.
Old 09-04-2007, 06:06 PM   #10
XR6_661
Cane Farmer
XR6_661's Avatar
Do the hybrid motors have a greater power figure then that of the non-hybrid motors?
Old 09-04-2007, 06:13 PM   #11
rmack
rmack's Avatar
I believe the EL and the AU Series 1 both have the same power.
157kW @ 4900 rpm.
357Nm @ 3000 rpm.
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 09-04-2007, 06:14 PM   #12
ED_Boy
EL Futura T5
dunno the exact colour but its like a ruby red, i think its called regency red or cardinal red im not sure ill get back to ya when i get the colour code
Old 09-04-2007, 06:17 PM   #13
ED_Boy
EL Futura T5
cheers thanks for all the help, mine is a 97 motor so it probably isnt subject to the hybrid
Old 09-04-2007, 06:18 PM   #14
ED_Boy
EL Futura T5
i know this is off the topic but does anybody know how much a set of pacemakers will set me back?
Old 09-04-2007, 06:21 PM   #15
ilsautomotive
In future, please post your enquiry in only one thread. I have merged the 2 here. I'd suggest using the search facility for information on Pacemakers.
For interest's sake, whilst AU power figures were the same, I believe the torque curve was improved slightly.
Old 09-04-2007, 06:37 PM   #16
wodahs
wodahs's Avatar
they cost me about $350 from repco
i did a head exchange from veale coz the price but both veale n repco said no diff in the head between falcon fairmon fairlane or xr just whether its a late modle el coz of the au head situation - being that other bits dont bolt up properly
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 06:48 PM   #17
Jason[98.EL]
well i know i have a hybrid engine in my el
i had a good convo with the guys at "surecam" i dont normally name a company that are not a forum sponcor but this time i think i must
the person i spoke to told me that the el from 5/98 build had a full au engine
anything before that had a mix like rmackhas said in post #8
......(disclaimer)..... now i will not stand by this info as i only got it over the phone
now if this is right i need an au cam for my 6/98 el
if he is wrong wtf do i need an e-series cam def wont fit
jason
[SIGPIC][/SIGPIC]
Old 09-04-2007, 08:56 PM   #18
Bens_ELXR6
SupahStah
Bens_ELXR6's Avatar
jason
Well, I got my cam. It was said that it would work for my hybrid motor, wrong cam, almost bent a valve.
As a result I am going EF head. Easier to change around heads than have my car off the road with damaged pistons / valves lol
You have to be very carful the people you talk to know exactly whats going on. Some can be easily confused on this issue lol
Cheers,
Ben
Bens_ELXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 07:22 AM   #19
XR6_661
Cane Farmer
XR6_661's Avatar
jason
Well then mine must be a full AU motor then as well?
Mine was one of the last to roll off the line.
I think that 'tighe' do cams to suit the hybrid motors....Don't quote me on that though...
Old 11-04-2007, 06:12 PM   #20
Bipolar
I'm back. Same car.
Bipolar's Avatar
Is there an actual date from which the hybrids were produced to look for on the build plate?
Bipolar is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 06:42 PM   #21
Dezza
Parts bin special
Dezza's Avatar
I think the ELs fitted with the "hybrid" engine also had a black painted engine bay, and had an unpainted rocker cover or something like that
Old 11-04-2007, 07:57 PM   #22
335JET
@jas_23_
335JET's Avatar
hybrid motors are stamped on the head with 96DA.
Old 11-04-2007, 08:08 PM   #23
Jason[98.EL]
mine has a painted engine bay
the rocker on mine is not painted though
jason
[SIGPIC][/SIGPIC]
Old 11-04-2007, 08:15 PM   #24
335JET
@jas_23_
335JET's Avatar
Heljas, what is your head stamped as.
should be 96DA.
