Old 09-04-2007, 05:56 PM   #1
ED_Boy
EL Futura T5
Default XR6 Head Enquiries
Hey Guys & Girls
Does anybody out there know the exact differences between the standard and XR6 head, I've heard the intake valve heads are 2mm wider and the cam has a slightly more aggressive grind on it, would it be worth putting one of these heads on my standard 4.0? if so what are the advantages?
Cheers, Daniel
ED_Boy is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 07:43 PM   #2
bucko
bucko's Avatar
I wouldn't think the valves are any bigger but they do have a slight more aggressive cam over a standard 4.0 cam. Your better off putting a wade or crow cam in.
bucko is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 07:43 PM   #3
webby_191189
low wagooon
Your head would flow a bit better and you get a slightly larger cam. You might notice a small gain.
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 07:48 PM   #4
gthofan
Gunna girlie-man
gthofan's Avatar
and higher compression
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 08:19 PM   #5
bucko
bucko's Avatar
Do you gain compression by putting a bigger cam in???
Old 09-04-2007, 08:23 PM   #6
gthofan
Gunna girlie-man
gthofan's Avatar
no the head has higher compression.
standard head- 8.8:1
Xr6 head- 9.1:1
Old 09-04-2007, 09:41 PM   #7
CozEF
CozEF's Avatar
the exhaust valves are 3mm bigger on the exhaust side as well apparently, haven't actually measured them myself but thats what i was told
CozEF is offline   Reply With Quote Multi-Quote with this Post
