Digging for avatar
Hi everyone, since getting my au1/2 back from from Ford "service" (to get the cruise control fixed, $350 to find a broken wire then $350 to replace the whole turn signal,horn ect , ect, harness instead of just fixing the wire, then the "service" guy tells me how lucky I was
was extinct but got better. |
![]() Join Date: Jan 2005
I would say the worm gear in the door actuators is busted. Easy (temporary) fix is:
1. make sure child lock is off (so you can open door from inside) 2. Remove interior trim on rear doors 3. Remove the actuator rod between the outside door handle and the locking mechanism. 4. Recheck to make sure doors open when using inside door handles 5. Replace door trim. This should mean that your car can't be opened by the external rear door handles, but make sure the inside ones will open it before replacing the trim, otherwise the only way you will ever open them again is by using an oxy or grinder. The permanent fix is to either fix the worm gear in the door actuators (small cost, but takes time), or buy new actuators and fit them (large cost - around $180 new, or $75 scond hand and not much less time). There is an article somewhere in the BA section, I think, that details how to fix them using a drill, superglue and a smallish machine screw.
Digging for avatar
Thanks for the cheap quick lock the the car fix JC I'll go with that if it is actuators I cant afford new or second hand ones right now, but I suspect some kind of puter glich, it just seems too coincidental they should both go at the same time and I know ford was running all kinds of tests on the thing to find the cruise control problem, Im guessing they put power where it wasnt supposed to go, thanks.
#4 | |||
Digging for avatar
Gotcha. Im going to try disconecting the battery for an hour, cant hurt.
