Old 12-05-2007, 03:53 PM   #1
FOON
Default AU1 almost stalling on hard stops.
Hi All,
My AU1 6 cyl auto sedan is almost stalling when you stop hard/quickly. It happens in forward and reverse gears. If you stop slowly it's ok. If you keep your foot on the accelerator (keeping the revs up) and left foot brake, it's ok.
I have searched the forum but I didn't find anyone having exactly the same problem.
I have cleaned out the ISC with carby cleaner and gone through the computer idle relearning process as well - still the same. :
Please help me.
FOON is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 03:58 PM   #2
bodes-sh
don't stop as fast....? how is the base idle, when you have it in gear what speed does it idle at? also when did you last have the trans serviced?
Old 12-05-2007, 04:33 PM   #3
FOON
Hi bodes-sh,
Stop fast... sometimes you just have to.
Idle is 650 in park and 550-600 in drive.
Trans fluid, filter and seal were replaced today - but before that it hadn't been replaced for around 40,000klms...
Thanks.
Old 12-05-2007, 07:53 PM   #4
SirHenry
Falcon Unbelievable!
Sounds similar to my base idle problem, was doing similar things nearly stalling under brake and too low in the revs dept from memory I think revs should sit about 800 (not sure on that one though )
Mine was caused from battery issues. Not sure if its the same thing but something to consider anyways.
SirHenry is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 07:58 PM   #5
bodes-sh
this may help, it's a pretty old thread, but sounds similar to your problem http://www.fordforums.com.au/showthread.php?t=58617
Old 12-05-2007, 09:10 PM   #6
Soundwarp
Blue to the bone!
Soundwarp's Avatar
Mine did that after 6 months of sitting still, i had to get it to ford and they just cleaned the injectors and it was all good!
BA GT-P in the garage
http://img.photobucket.com/albums/v7...dwarp/fbar.jpg
Soundwarp is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 02:47 PM   #7
FOON
The AU is fixed!
It didn't take much. I bought a bottle of Injector cleaner (Castrol) that you poor into the tank. Less than 20klms later it was running as good as it can :togo:
Thanks for your replies.
